I have a spare car audio subwoofer enclosure with (3) blown 10" subs in it.
I also have a main home audio receiver and a spare home audio receiver. The main audio receiver has a pre-subwoofer output.
My desire is to:
(1) Replace the damaged subwoofers
(2) Use the main receiver's pre-sub out (to get the isolated low-frequency signal) and go into any input (ie: CD) of my spare home audio receiver, and then wire the subs to the Left or Right speaker output on the spare amp (or bridge them?)
Based on the limited research I've done online, I believe this is "safe" to do (ie: the amplifier should be able to power all 3 subs since it is dedicated to only the subs, and not get over heated), and I believe this will also give me the capability to use the spare amp to independently control the volume of the subs.
I would love to get an audio expert's thoughts on what I've proposed, and/or a link to a wiring diagram that I can refer to in terms of how to safely wire the subs so that I am able to match ohms (ie: series vs. parallel and bridge or mono from spare amp to subs).
Concerns:
1. Most subs I see online are 4 ohms, but my receiver is 8 ohms. I believe this can be solved based on how I wire the system.
2. Do I need to consider single-voice coil subs vs. dual voice coil subs?
Thanks!
