Hey guys, I'm having some trouble pairing my front L/R speakers (Klipsch RP-280FA) to my Subs (Klipsh R-112SWs).
I've got 2 subs in the front corners and fairly well balanced using a mini DSP:
However, once I run a sweep pairing either L or R with the subs (crossover at 80hz), I start seeing a large dip at 70 and 100hz, and a sharp peak at 120hz:
I've tried several different subwoofer delays to get the speakers more in phase, but this is actually be best I could do (+6ms). Anything up or down makes it even worse.
I've also tried going without YPAO EQ (worse); and manual GEQ where I kill the L/R speakers 60hz output and bump the 160hz output. The result was worse. The GEQ on the Yamaha TSR700 doesn't feel fine enough for this kind of work.
I do plan on putting some 3" acoustic absorbers behind the L/R speakers on the front wall as well as directly to the sides to cut down on some SBIR effects, but I'm pretty sure that won't do much at the 70/100hz problem areas.
Any suggestions for what else I can try? Thanks!
