Need Headphone Amp Suggestions for...
Knucklehead90
Knucklehead90
Peavy is known for making excellent audio gear - they market a headphone amp that might interest you. As baffling as it may seem - the power supply is sold separate. I imagine a generic one from Radio Shack could be made to work.
sholling
sholling
I've used headphone amps from headphone.com in the past and was pretty happy with them.
ubila
ubila
The Little Dot III seems like its gonna be a good buy.
And unlike most, its available at a local store here in New Zealand.
Unfortunatly its $360 haha.
I cant really tell but is that a 1/4 headphone jack on the front?
If its a 1/8 will you loose quality using a convertor? (My HD595s have 1/4 jack, although it did come with a convertor)
Cheers
WmAx
WmAx
Headphone amps, like speaker amps, are usually heavily laden in snake oil reputations of sound quality claims that are fictional.
Exactly the same issues are true with heapphone amps as are with speaker amps: frequency response, distortion/clipping characteristics and the load interaction with the headphone used on the system.
Do you want a capable device or a decoration that will cost a premium just for cosmetics? It really comes down to this.
A low price and transparent house voltage powered (non portable type) headphone amp with much more capable driving ability than most (due to it's higher than normal power supply) is a Behringer Xenyx 802 mini-mixer. It's headphone section is excellent. It also has high versatility since it's a mixer.
Add a high quality DSP EQ and you will have one heck of a capable system. Use a Behringer DEQ2496 added with the amp, and you will have incredible SQ potential. The DEQ also has a spatial effect that is variable and can be used similar to a crossfeed effect. If the crossfeed effect is not needed, the DCX2496 is a better choice: it has more capabilities/flexibility that extends to improving high end speaker systems as well.
If you need special crossfeed effect function as found on some amps, though, then the behringer unit is of course not suitable.
-Chris
ubila
ubila
Im really just looking for the best possible sound quality i can get for my limited budget. (im a student).
I want to get a standalone CD Player for the sole purpose of driving my Sennheiser HD595's, and conncect an amp to it. Wether it be headphone amp or a big amp unit. Whatever is better, and in my price range really.
Are you suggesting that the bigger nonportable amps like something you find on a home audio system, would be a better option then a headphone amp?
cheers
WmAx
WmAx
cheers
I'm just saying that a transparent, very capable headphone amp can be pretty inexpensive. The Behringer 802 unit I mentioned above is all you need if function comes before cosmetics for you. Combine this with the DCX2496 and you have huge SQ potential, because the DCX allows very precise/accurate manipulation of the response far beyond a 'regular' EQ. You can adjust 'tightness' of bass, exact treble response properties for realistic balance, etc. with such an exacting device, unlike a regular EQ(which are pretty worthless IMO).
-Chris
MidnightSensi
MidnightSensi
A while back I built a Meta42 headphone amp out of a kit, off that head-fi website. I think it is outdated now, but I'm sure they have another kit with the latest and greater.
This Meta42 sounds excellent and didn't break the bank.
MinusTheBear
MinusTheBear
cheers
From looking at the specs of the 595 they are a very easy headphone to power. Any device can power the 595 to comfortable levels. You can also forget about the headphone amp and get something like the Sansa Clip+ 8gb MP3/Flac player and purchase some MicroSD cards to go with it so you can use the external memory that is available on the unit for extra storage capabilities. Convert your music collection to Flac preferably and transfer to the Sansa Clip+. The clip+ should do an excellent job at powering the 595 and will also work well as a source.
Y
yepimonfire
i own a sansa clip, i love that thing and it has plenty of power to drive hard to drive headphones.
Y
yepimonfire
cheers
well, it would do the trick and certainly be a better investment, it has a headphone amp already in it obviously and you can later add an inexpensive set of bookshelfs to it like B2030p's or Polk monitors. etc. if you have a DVD player you could listen to the DVD's over the headphones and use it to play your CD's.
Y
yepimonfire
a large set of Koss headphones, forget the model name but i could crank an ipod to the max and still want more volume with them, only way i could get a pleasing volume from the was my receiver or the sansa.
sholling
sholling
I was just curious. I've never found an MP3 player that could drive my HD600s but I haven't tried every MP3 player. I'll try my 280e and my Fuse and see how they do. Not that I'll ever use them with an MP3 player, I have UE TripleFi 10 Pros for that.
ubila
ubila
Its funny, my iphone seems to drive my headphones better then my pc sound card lol. Spose that says alot about my sound card >.>
MinusTheBear
MinusTheBear
Make sure that the master volume is up very high on the computer (usually found in the taskbar) so the headphones are receiving enough gain so you don't have to max out the volume control on the media player that you are using.
WmAx
WmAx
A true 'hard' to power pair of phones would be AKG K1000 and K340. They require much higher voltage than a portable unit can provide; even a *9VDC powered dedicated headphone amp is not suitable. I conducted extensive analysis of this issue and the K340 required in excess the RMS VAC output that most portable amps can not provide. Even many home headphone amps may have insufficient output voltage.
http://www.hydrogenaudio.org/forums/index.php?showtopic=39106&st=25&p=354399&#entry354399
-Chris
*Voltage reference presumes standard analog power supply. A digital switching PS(very rare to find in such portable amps) can operate the audio circuits at a much higher voltage than the battery base voltage allows in a standard analog system.
BoredSysAdmin
BoredSysAdmin
No, that say much about your sound card at all, I think Sound Blaster 16 was about one of the last sound cards with good headphone amp in built in,
all newer sound devices reply on external amplification.
However if you are hearing hiss and other noises while headphones plugged in and nothing is playing = sound card sux :)
sholling
sholling
One of the last Sound Blasters or one of the last cheap cards with a decent headphone amp maybe. Look at some of the offerings from HT Omega.
