Also, sorry to have neglected giving you guys PROPER KUDOS via likes and all. I was unaware I could do that. I've never been a member in a forum. So let me see what I can do about giving you all your proper due!!!!!!!!
There's no need for apologies at all Clay!
In fact you should be commended... in my short time on the forums (here and AVS) this has to rank as one of
the best conducted "beginner/help" threads I have seen. You do your own research, ask relevant questions, give good feedback and move through logically... very well done. So KUDOS to you Clay! I genuinely hope that you
won't ride of into the sunset when your purchases are made and installed, but continue to come here to learn more and contribute. I think you have a lot to offer.
On the Speaker Wire, I know its not REALLY NECESSARY performance wise, but I am thinking of rewiring with the Blue Jeans Cable Belden 5000 Series White AWG12 (the 5000UE in their pricing calculator by foot indicator) because it is actually rated for In Wall Use as opposed to zip line. I figure I might as well use the right stuff since its the same work pulling it. I know the performance will not differ. Just being anal I suppose.....
It's always wise to use wire rated for it's particular use, in my opinion.
QUESTIONS:
Regarding the wiring, I was going to get the fattest gauge I could and reasonably pull and deal with. Ascend's owner Dave in one of their older forums said he recommends 14 gauge (minimum) but I haven't found anyone that can accurately state that Bi-Wiring their 340s produces better sound than decent gauge 2 wire.
Use your longest run and input the data into this calculator:
Speaker Wire Calculator ... and buy a spool of that. Wire of 14AWG should be fine out to at least 50ft according to
Roger Russell's Speaker Wire page. (Lots of good reading there too.) I wouldn't go to 12AWG unnecessarily, it doesn't make any difference electrically and just makes it more of a pain to pull through the wall.
The importance of wire is often overstated and is something that fellas spend far too much mental energy agonising over at times. It really doesn't/cannot make a hell of a lot of difference in the whole scheme of things. Just get good solid, economical wire of no more than the gauge you really need from a reputable vendor, install it and forget about it, forever.
Bi-wiring doesn't make any difference to the sound unless your using
grossly undersized wire in the first place. All bi-wiring does is increase the effective gauge of the wire and in, and of itself, cannot make any real difference to sound.
What do you guys believe regarding Bi-wiring versus regular wiring?? I am not talking about bi-amping but simply the wiring of the speakers. ANy benefit over going 12 AWG regular wiring????
The only benefit I can think of is having a spare run in the wall in the event of future expansion plans, or if for some reason you have a breakage or fault in a run.
Regarding the HSU Sub options, I think I have narrowed it for sure to these two. Now if the back order is not a significant issue, would you guys see a benefit in going with the VTF-15H MK2
http://www.hsuresearch.com/products/vtf-15hmk2.html which is only $100.00 more than the VTF-3 MK5 HP
http://www.hsuresearch.com/products/vtf-3mk5HP.html ??
Tough call. Based on their CEA 2010 averages the 15H MK2 plays about 1dB louder across the range. This is theoretically barely audible and only at the upper limit of their performance. The 15H MK2's advantage is at 16Hz in single port mode where it can play about 3dB louder (if required). Seeing as your looking to duals in the future anyway
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, I'd pocket the $100 and go with the 3 MK5HP for the smaller form factor (mainly depth) which will make duals easier to accommodate in your space.
Edit: Yep, I like Shady's advice to compare at Hsu. My guess is that you (and the room) will cop a good pummelling before you can pick a difference.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
