Azurik88
I have a pair of Boston VR1's. I'm looking to setup a music streaming system, turntable, and potentally home entertainment. Mostly I want to listen to music, so I'm thinking the music streamer route. I don't know if theres a one system solution or seperate component system that would be Worth it as sound good. I also don't want to over buy for the speakers I have. I'm looking for general advice or direction to previously posted threads. Thanks all
Tankini
All depends on your budget, even very low-end AVRs, Integrated or just a two channel receiver will be Able to stream, stand alone streamers can be had on the cheap . You have a good grasp of what you're looking for just jump on the Internet many good Options of what you're looking for.
Azurik88
Gotcha. Let me be more specific.
WiiM Pro Plus 219$
Fosi Audio ZA3 Balanced Stereo Amplifier Home Audio 2CH Mono Amp With TPA3255 Chip 109$-149$
Input: RCA, XLR, ¼”TRS; Output: Stereo, Mono
SNR≥106dB; THD<0.006%; SINAD: 89dB; Frequency Response: 20Hz-20kHz (±0.1dB)
Rated Power Output: Stereo 180W*2 @4Ω; Mono 235W @4Ω
My speaker specs
46Hz-20kHz 15-150 watts 8 ohms 93dB
(2) 61⁄2" DCDTM (165mm) copolymer
1" (25mm) VRH.O.TM anodized aluminum dome with AMDTM
2700Hz
will the foci monos over power my speakers? Do I need anything else or what component would you suggest adding just for music streaming?
Cambridge Audio CXN100 1099$
Rotel RB-1582 MkII 2199$
the price range is either 500$ to 5000$
I don’t want to Over but for my speakers, so I wanted to see what y’all’s thoughts were
Bobby Bass
Bobby Bass
I have the Rotel and it’s excellent. Highly recommend.
