Well, you could, but it would be very unwise and make absolutely no sense. To be blunt about it, it is an idiotic plan, with only negative merit. For a start will be stacking preamps, and likely run into gain structure issues, and even input saturations, as well as adversely affecting you signal to noise ratio. Lastly your receiver has better more powerful amps than your Integrated amp. Receivers give better value for money then integrated amps because of economy of scale. So what you plan is a significant downgrade and quality spoiler on many levels.
If you think you need more power to your main speakers, then you need to purchase a dedicated power amp in the 250 to 300 watt per channel class.
