OK. These are common problems and there is certainly a cause and a solution. I prefer to be methodical on the troubleshooting instead of the shotgun approach.
My very first question/suggestion: Are you using SHIELDED signal cables from the PC to the speakers? If not, that would be my first step (with the limited info that I have on the problem).
Now, does this sound like a "hum" (a 60Hz hum)? Or is it static/noise? Do the speakers have a 3-prong plug or a 2-prong plug? Is ALL of your gear plugged into the same outlet? Are you using a surge protector? What other appliances may share the same circuit on the panel (refridgerator or light dimmers are common problems). Do you have a cable box hooked up?
Can you temporarily hook the speakers to a different source and see if the problem goes away?
Do you have the digital volume at 100% on the PC, then control the volume through the speaker knobs only?
Shielded: I don't think so. I got the cables from Micro Center on short notice because the other option wasn't working well, and their selection was limited.
I think these are the ones. (Or maybe they were 6ft) What shielded cables would you guys recommend? Even if it doesn't solve the problem I'd feel better having shielded cables.
Hum vs noise: definitely more like static.
The most unique part of it is that it changes noticeably based on what the video card is doing. I don't know if that makes the video card the cause so much as what's making the symptoms more noticeable. The details of the effect change from game to game. I showed WoW in my example, but also Heroes of the Storm does it, but is more consistent about it, and for some reason Overwatch hardly does it at all. It doesn't seem to be based on what is being shown to the monitor. To test this better I tried turning my monitor off when I'm in a game, and while it does change, it doesn't change until a moment after the monitor has been off, seeming to indicate that the video card is changing how it's doing things (which is also confirmed by Windows having resized all my windows when I tab back out - a common downside of using a 4K monitor with Windows). So, whatever the reason this is happening, it seems like the activity of the video card is directly tied to the result I hear, but almost certainly the monitor and its cable is not. The kicker to show that it's really not the monitor is that having World of Warcraft in the forgound causes it, but if I have WoW in the background (I use "Windowed Fullscreen" mode) and shrink whatever's in front of it to almost nothing the issue doesn't happen. So what's being shown on the monitor is definitely not the issue.
The speaker cables are not "pronged" at all, they're
male-to-male 1/4 inch cables.
When plugged directly in to my motherboard's onboard sound card I was using variable sound levels in Windows as the primary means of controlling the volume. When I switched to using my mixer I discovered soon after my last post here that the problem was made worse by having my PC sound to the pixer permanently at 10% and controlling the sound at the mixer.
I now keep Windows' volume at 100% and keep my mixer volumes low, and this has helped a fair amount, though it's still very noticeable when doing many things.
Here's a rundown on all the steps of my setup:
- Plugged in to the outlet is a fairly basic large surge protector. (I used to have an uninterruptible power supply here, but it died and I've just been dealing with a plain surge protector since power outages have been very rare here in recent years anyway)
- Also plugged in to the same outlet is a 3DS charge cable leading to a 3DS which spends most its days untouched and charging.
- Things plugged in to the surge protector:
- Computer (the actual cable going to my custom PC's power supply)
- 4K Samsung Monitor
- My mixer: Alesis MultiMix 8 USB FX
- External hard drive
- A semi-old Toshiba flat screen TV which I only use rarely (never when testing these things).
- Both speakers
- An official Apple USB charging port that has a lightning cable attached to it. Used on occasion, but not while testing this.
- From my computer I'm using my mixer via USB.
- From the mixer my speakers are connected to the MONITOR jacks L and R.
- Also plugged in to the mixer: A condenser microphone via XLR cable
- A 1/4 inch to 3.5mm adapter is plugged in to the headphone jack so I can have my headphones plugged in.
- I've uploaded a screenshot of my mixer setup here.
Also, to everyone who's posted here so far or in the future:
Thanks for all the help! It's been great to have the feedback of people more involved in this stuff, and I really appreciate it.
