N
Nouse4name
I will be using it for about 70% music and 30% movies. My room is 10x12 so its pretty small. I was looking at the ed a2-250. Would this be a wise choice? This is my first subwoofer so I'm a bit unsure. :confused:
sholling
sholling
That's a small room so it shouldn't take much. Just keep in mind that it's down firing and if you have anybody under you you'll probably want an isolation pad.
N
Nouse4name
I'm in the basement. :cool:
Budget is around $400
sholling
sholling
Then I'd probably go for overkill and an A2-300 just because.
E
erslageorge
Hi, I also mostly use to 70% to music and 30% 'movies and my room size is 12 14 and ceiling is 7 feet that is neither large nor high. Would you please recommend me the Dolby digital surrounding system sub-woofers?
GranteedEV
GranteedEV
In that size room I'd stick with a sealed sub like an Epik Legend or two Emotiva Ultra subs.
skizzerflake
skizzerflake
I have a 10 X 12 room and a Hsu STF 2 can shake the room. It's fine for both movies and music, fairly cheap at about $360 for woofer and shipping. I ordered on from the web and had it in about 3 days. It's strong down to about 25 Hz and I use a 80 Hz "brick wall" cutoff for flat response along with my NHT speakers. I don't think you can go wrong with this and, as good as it is, it's really cheap.
