Hi everybody - I'm looking for a sub to go with my new home theater. I'm not looking for earth shattering volume levels, in fact, i probably rarely will get to listen to this the way I want However, for most things, I want it to go low and strong. Probably a mix of 50-50 music-movies, but if I had to choose, I would pick music first. Budget of around 1000-1500. I don't want to go too much higher, but will at least consider it I can find the right sub.
Some of the nice-to-haves:
EQ - to deal with any strange dips or peaks
remote
I would like to be able to walk around the thing in less than an hour (i.e. space/WAF is sort of a factor)
My room dimentions are about 15.5' x 21' x 7.5', with about a 750 cu. ft vaulted ceiling over half of the room (total of about 3300ish cu. ft) This will be used with the Energy RC-70 mains, center, and surrounds. Denon 3806 receiver.
So far, I'm interested in:
Velodyne SPL-1200R
Axiom EP-500
Anything else I should look at?
To sum up: Music, low, strong, but not bring-the-house down loud.
Thanks!
