nad c 370 with cerwin vega speakers
G
grovers7200
I just refoamed my 20 year old AT 15 cerwin vegas and they just continue to jam.. I have read alot about 4 and 8 ohm but still in the dark?? Should there be a special way I hook my 4 ohm speakers to this amp or just as I did pos to pos neg to neg left and right?? Thanks..
You hook them up normally.
What do you mean, continue to jam? I assume you mean you have gap rub. Did you remove he dust cap, and use voice coil shims when re-foaming? You have to use shims to center the gap, and then remove the shims and replace the dust cap.
3db
3db
By saying continue to jam, you mean they're still working great?? ;)
That NAD is more than capable of handling 4ohms loads so don't even give it a 2nd thought. Add the fact that your CVs are extremely efficient so you don't need alot of power to make them play loud.
G
grovers7200
Hello thanks all I did was put new foam on my cerwin vegas I did not know there was much more that I could have done to them??
