My wife is going to KILL me!!!
Pyrrho
Pyrrho
I was actually super surprised when I told her. I asked her if I had a lot to drink the night before. She said yea. I said I must have cause I ordered a $6,500 integrated amp. She looked at me and laughed. O well, you work hard. I smiled and told her how much I loved her. I'm gonna be drinking more often from now on. :D
I think this sort of thing depends greatly on how much money one makes. If you are pulling in a seven figure income, she should not care at all, unless you are squandering the rest of it. If you are making $40k per year, then she should probably be angry with you. Somewhere in between is where it would be questionable, though I do not wish to bother thinking about what sort of income it would be to be questionable. It also obviously depends on what sort of other expenses one incurs.
flyboylr45
flyboylr45
Well it's not 7 figures but it's definitely a lot more than $40,000. Like i said to her, I'm not taking food out of your mouth, our daughter's or our retirement. Only one life to live.....
And yes, I am looking at the Concept turntable.
Pyrrho
Pyrrho
Definitely a lot more than $40k suggests that her reaction may be quite reasonable.
I used to be poor, and then my wife would have been upset (justifiably) for me spending money the way that I spend it now, if I had done such a thing (which I would not). It is all a question of balance and proportion to what one has, not the actual amount spent. I personally would not spend $6500 on an integrated amplifier, though I have more than that invested in my systems. Of course, if I had a 7 figure income, then I would not worry about spending $6500 on an integrated amplifier; I would buy it if I really wanted it. But at my actual income, I would not do it. And I would be buying speakers first, not the amplifier first, just in case I ended up with something with special needs. Right now, my main stereo has speakers with a nominal impedance of 3 ohms, and so I purchased an amplifier rated for such use. They are the best sounding speakers I have ever owned; too bad they are not made anymore.
Anyway, for a $6500 amplifier, you should be planning on spending quite a lot on speakers. There is no sense in paying that much for an amplifier to use with cheap speakers.
flyboylr45
flyboylr45
I pulled the trigger on the Clearaudio Concept. I have 30 days to try it out if not I can return it. This is my first turntable and can't wait to start listening and buying more records!!!!!
flyboylr45
flyboylr45
Here are some pictures of the room I built. I am waiting for the MA7000 which I got a call saying that it's going to ship Monday and will be here by Thursday. The speakers arrived and I LOVE them. Tomorrow I receive the rest of the acoustic panels which are 2 monster bass traps for the rear and 2 soffit traps for the front. I am also enjoying the Clearaudio Concept TT. I was running everything with the Rotel and Marantz processor but since then moved everything where it belongs since the Mac will be here this week. I am still listening to the Focals with my Emotiva mini-x amp!!! That little amp sounds really good. Can't wait to have the rest setup. Any comments, suggestions or critiques will be gladly taken!!:D:D
The last picture is of my theater/family room. You can't see it from the picture but the table between the sofas is the SVS PB-13 Ultra. ;-)
flyboylr45
flyboylr45
Here she is!!!!!!!! Finally at home.. I LOVE the way this sounds. The room has an area rug and a compliment of GIK acoustic panels. There are 3 242 for side and ceiling first reflection points, 2 soffit bass traps at the front corners, 2 242 next to the soffit corners, and 2 monster bass traps in the middle of the back wall. I worked with Bryan from GIK and I am extremely happy with the results and the way the system sounds.
3db
3db
I've had a few drinks and was reading the forum while listening to Placido Domingo and all of the sudden got the urge to look at Macintosh gear. I've always been a fan of integrated amps and out of nowhere ordered an MA7000 for $6,500!!!! Luckily she doesn't have to work and I take care of her kid (my stepdaughter which I absolutely LOVE). I'm sure when she sees the new green meters and my smiling face she's gonna know something is up. Since she doesn't work all it takes is a simple google search and I'm TOAST!!!!!
At least you will die happy. :)
Awesome looking amp. How much power is it usually outputting?:D
flyboylr45
flyboylr45
Almost always over 2.5 watts. Usually I see 25 watts constantly when cranked up with peaks of just below the 250 watt numbers which are a little to the left of the 250 watt tick mark. I crank the music pretty loud most of the time. I'm loving it.
