My router login page not working. Any Troubleshooting steps to follow?
routerloginsetup
routerloginsetup
I am unable to access my netgear router login page. Any views and suggestions for the same to fix the issue asap. Thanks
slipperybidness
slipperybidness
Are you certain that you have the correct IP for the router?
Are you certain that the router is operating properly?
Look on the router's label- it will show the IP address and login- is it possible that you used xxx.xxx.1.x instead of xxx.xxx.0.x (or vise-versa)?
What kind of computer and which OS are you using? Find a way to enter command prompts and type 'ipconfig', then click enter (omit the ' at each end). Among other details, it will show the gateway IP address as 192.68.x.x and if the computer isn't connected, you'll see something like 169.x.x.x
