My move came in
  • Thread starter Thread starter j_garcia
The update for Heavy Rain just came out. It is quite a large download. Yes you need both controllers for this one. Many other games only need the move controller. The starter pack does not include the joystick controller.
So the Heavy Rain update came out? How is it?
Yeah thats what i fugured bout haveing to buy the starter pack and the joystick. They def didnt make owening the Move very cheap thats for sure. So it looks like if I want 2 ppl to play its going to cost me around $250 plus tax. Thats almost a turn off for ppl.
Thanks for the info tho.
$250? The move bundle saves about $10 and the joystick controller is $30, so should only be around $130. If you put heavy rain in right now, it will update. They changed the loading menu to work with move and it is pretty cool. I only tried the first section briefly and so far it is interesting, but weird to get used to at first because it is so different from the dualshock. Holding the move in a specific orientation will take some getting used to also.
You may use a DS3 in the other hand instead of the special navigation controller.
Just FYI...
Just FYI...
It sure does, but trying to hold and use it with one hand is not exactly easy.
