MY M570 REVIEW - PERFECT CANS
johnny45
johnny45
AN ALL AROUND GREAT SET OF CANS , BUILD QUALITY AN SOUND QUALITY I
KNOW SOME PEOPLE TALK ABOUT THE RINGING ISSUES AROUND 800HZ BUT
THATS NOT REALLY A
PROBLEM FOR ME A WITH A LITTLE EQ'ING THAT GOES
AWAY SO DONT LET THAT DETER YOU FROM BUYING , IVE YET SEE OR HEAR OF
A SET OF CANS UNDER 1000$ THAT DOESNT NEED
OR BENEFIT FROM SOME
EQ'ING AN TO ME THE RINGING ISSUES AROUND 700 - 800 - 900HZ IS MORE
IS MORE PRESENT DEPENDING ON THE TRACK YOUR LISTENING TO SO WITH
EQ
THER NON EXISTENT IM CURRENTLY DRIVING MINE OFF A JDS ATOM FEED
FROM A TOPPING D10 DAC ON HIGH GAIN I NORMALLY RUN ON LOW GAIN
WITH THE DAIL AT THE 9:00 A CLOCK POSTION BUT ITS NOT AS LOUD AS ID
LIKE ALL OF THE TOOL ALBUMS SOUND GREAT VIA THESE ESPECIALLY THE
LATEST ONE , SOON ILL BE
UPGRADING TO A AMP WITH MORE JUICE THE
ATOM PUTS OUT 1 WATT AT 32 OHMS I THINK THAT ONE WITH 2.5 TO 3
WATTS IN LOW GAIN WILL BE THE SWEET SPOT IF I CAN FIND ONE THAT DOES
ILL EITHER GO WITH THE MAGNI HERESY OR THE DROP + THX AAA™ 789
LINEAR AMPLIFIER FOR THE XLR INPUTS FOR FUTURE PROOFING OR MAYBE THE
ASGARD 3 IS WHERE IM LEANING
HERES SOME STILLS OF MY SET WITH
CUSTOM CABLES FROM HARTAUDIOCABLES
johnny45
johnny45
my caps key gets stuck an untill a new keybourd is got its easier to leave it on
also not the best position on bourd offen gets wacked then sticks
johnny45
johnny45
updat to this ive
i just cranked the dail on gettin an amp for my cans ive just bought the Schiit Magnius im very happy
after seeing an reading the audiosciencereview on it
i decided to go with it instead of the monoprice balanced
original was going to start with the monoprice balanced but this is better an i save 200$
the Schiit Magnius is
part 1 of my dream stack
part 2 will be the DROP + GRACE DESIGN STANDARD DAC BALANCED
part 3 will be adding an eq either the Peavey PV 215EQ Graphic Equalizer or
the ART EQ-355 Dual 31-band Graphic Equalizer because i like physical dials and switches
more than digital the Peavey PV 215EQ
is great i use 4 in my ht setup but im leaning torwards the ART EQ-355 Dual 31-band Graphic Equalizer
for the 32band fine tuning an ther high an low trims any thoughts on this id like input from you
part 4 accessories will be some custom xlr headphone cables from
https://hartaudiocables.com
an some interconnects from proaudiola
ill post pics once it all arrives
Joe B
Joe B
Not related to price?
I understand that just because there is a high dollar value on a set of headphones doesn't necessarily mean their sound quality is good, but won't you say that in general, there is a correlation between price and sound quality?
Isn't the same true about speakers? If it is not, please, please let me know of a set of headphones in the $300 range that can compare to the sound quality of a pair of Focal Utopia headphones.
shadyJ
Speaker of the House
Staff member
Read the research that is linked in that article. Headphones are a minimum phase system and are not affected by the complexities or room acoustics or crossover circuits, and, to a lesser extent, are not plagued with non-linear distortion problems. So the problem of headphones is almost entirely a matter of linear distortion, i.e., frequency response. The thing is, out of the headphones measured for that research, frequency response variation was all over the map and was not correlated by cost.
The research done to study human preference of headphone sound showed that the preferred response was largely that of a neutral sound source within typical acoustic situation, much like loudspeakers. Accuracy is the most preferred sound, again. The problem is that accuracy was shown to have nothing to do with cost. The headphone market needs a serious deflation in light of this research. The thing to do is buy some headphones that have been measured to have an accurate response and just make sure they are comfortable. After that, EQ them to taste. Anything else is just burning money for no return.
I don't know about the Focal Utopia headphones, but if their engineers didn't have regard for the research in headphone sound quality, they could easily be worse than a $50 set of headphones let alone a $300 set.
johnny45
johnny45
well im not that knowledgeable inregards to all that to me they sound good an neutral an the accuracy to me was worth the cost an frankly 300$ is my limit for cans
my reason behind amp an eq upgrade is simple when i went from my fiio 10k little amp/dac combo an the digital eq in the pc which is what i originaly used for both my prevous set of cans the adh - 500x an my current m570
to my current combo the jds atom amp an the topping d10 dac without any pc based eq what i noticed was
better accuracy an better frequency response at high volumes an less distortion problems also at high volumes
the reason i decided to pull the trigger on the Schiit Magnius and am aiming for the DROP + GRACE DESIGN STANDARD DAC BALANCED
an exturnal eq is a high school buddy of mine had a similar setup to my intended that i pluged my newer m570 into an the better amp an eq tuning was a great difference of an experience to my current setup
tracks that i found unplesent at desent volumes an sounded distorted an not accurate compared to how they sounded in the past on other systems just dont come across the same on my current setup
so hince the upgrade to the mentioned
my friend had a little over a 1200$ stack a over 400$ per unit amd , dac , eq , etc
an while i was never going to spend that amount to great the performence that i want an had
experienced
i did get a look at the specs of his gear an found that they were nearly the same as my purposed stack
so after reading the review on the Schiit Magnius and DROP + GRACE DESIGN STANDARD DAC BALANCED
i decided to go with them a, as of now iv bought the Schiit Magnius an about to get the dac
im just tring to decide on the eq as mentioned
which would be a better addition to my stack
the Peavey PV 215EQ Graphic Equalizer or the ART EQ-355 Dual 31-band Graphic Equalizer
my budget limit for any piece of gear is 300$ on the nose with an additional 50 max to cover tax an shipping so 350 period
