My latest DIY project: super budget computer sub
alexwakelin
My latest addition to my growing PC sound system has been a new subwoofer. For under $80 (shipping included) I built a pretty solid little sub that adds some decent thump to music and games. It hits down to 30Hz, compared to my old sub which would bottom out at 40.
I purchased the Foster plate amp from here for just $32:
http://home.comcast.net/~jhidley/
And paired it with the $23 Dayton SD215-88 8" driver.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-480&FTR=SD215-88&CFID=7523642&CFTOKEN=42018702
My finished sub measures 11.5W x 13.5H x 16D.
My computer setup:
My new sub, with the old one for comparison:
There are screws on top because I don't have enough clamps, I had to use a combination of both to hold it together until the glue dried.
I haven't decided if I will finish it yet. I may just throw some carpet on it.
lsiberian
lsiberian
My computer setup:
Very nice.
Djizasse
Djizasse
That will give games some impact :)
Did you modelled the box? What are the specs?
alexwakelin
Yeah, I used WinISD. The plate amp I used has 6db of boost at 35Hz, which made it tough to get a flat fr. It did however, allow me to use a much smaller enclosure. Without the built in boost I would have needed a box about 1.5 ft^3, the boost allowed me to make the box just .8 ft^3.
Djizasse
Djizasse
You seem to have space for a bigger sub. What are you waiting for?:D
