Alright gents, it's about that time again. PICTURE TIME.
I really wanted to measure today but I had two problems.
1. I don't have binding posts. (Should be here in a few days)
2. Since my cabinet work needs some work the front baffle does not fit without air gaps. Normally, I'd just use my PL Construction Adhesive to fill in the gaps, but then I wouldn't be able to put in the binding posts later without doing so through a 5" hole.
To solve these problems I did the following:
1. Drilled 4 holes in the back of my cabinet and ran wire though them to the tweeter and woofer. The wire fits almost perfectly in the hole so I'm not TOO worried about the response changing a whole lot due to leakage. When I get my binding posts I'll be able to hammer them right into one set of holes and PL the other set.
2. I bought a foam weather strip and filled in the air gaps between the front baffle and the rest of the cabinet. Not too pretty, but I don't feel any leakage even at low frequencies.
I'll have pictures and measurements up in just a few minutes.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
