Pics arrived
I would say this clocked in somewhere around a 3 on a difficulty scale of 10 (10 being hard). The cuts were pretty easy to make. The router took a few practice runs.
In hind sight a few things I would do differently:
1. With the thin wall PVC I really didn't need any internal support. Just glue into the routed holes and let it dry. Strong as an ox at that point. I think even over time with gravity on it, they will hold.
2. I should have put the PVC in LAST. It would have made reaching through the speaker holes and sealing the seams and corners MUCH easier.
3. Not have been cautious by not putting higher end drivers in (the Dayton RF 12"ers vs the Quatro). I was scared at screwing up a $260 pair of drivers. They model better at the lower frequency end of things.
4. Just used wood screws to mount the drivers, not the $3 mounting kit (Hex screws and T-Nuts).
5. Devise a way to make the speaker baffle both air tight and easy to remove.
Things I would do again:
1. Not use a plate amp when an external amp like the Behringer is at comparable cost. IMO the Behringer is the better amp.
2. Use 1" or 1 1/2" dowel rods for bracing. Forget about routing out braces. Dowel rods are rigid and rounded (air flow). Easy to work with.
3. Screw and glue. I know designs call for just glue and clamp. Screws helped speed up the build process.
4. Get table saw extension for running larger cuts. Saw won't bind and cuts will be uniform.
5. Use a non-silicon based RTV sealant. Worked great for keeping seams airtight.
All I have to do now is sand, seal, prime, and paint. Wife gets to choose the paint...
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
