my DIY end/cocktail table for my home theater/music room
tattoo_Dan
tattoo_Dan
bought a new "red wine" color cheapo 13" tom from ebay.
had a piece of smoked glass cut for the top
mounted a base to a round piece of plywood that fir up in the bottom
the red wine color matches the rosenut speakers and cherrywood wall units in the room
STRONGBADF1
STRONGBADF1
Pretty cool!
did you dampen the heads so you won't get any sympathetic vibrations?
tattoo_Dan
tattoo_Dan
Pretty cool!
would the glass on top and the plywood in the bottom do that ok ?do you think ?
and it's at the opposite side of the room from the sub,I don't hear anything weird from it,if that's what you mean .
tattoo_Dan
tattoo_Dan
that also goes with the guitars and ukes
and soon there will be an alto sax hopefully :D
STRONGBADF1
STRONGBADF1
Probably is doing the job. As long as the head cant vibrate, you're good. (It would need pressure against, it away from the shells bearing edge.)
Yep that's what I mean. It would hum or buzz from the vibration. I guess the easiest fix would be to just jam a pillow inside it.:)
I have this dream of putting all my stuff in a mancave. It was dashed when I remembered that my drums would vibrate and make nosie when the home theater was cranked. (could buy some electronic drums...there is this Roland kit for about $5-6000 I like.:rolleyes::cool:)
STRONGBADF1
STRONGBADF1
looks like a great place to put the refreshment of your choice!
If head vibration is a problem, go to a music store and buy a head damper- some toms have them and it's a metal bracket that screws to the inside of the shell and has an adjuster to raise or lower the felt pad to increase or decrease the dampening effect. Should be pretty cheap.
That would be a good table for playing 'Quarters'.
darien87
darien87
Does the dog/cat smack its head on the speaker stand when it comes in through the doggie door?
I can just picture the little guy coming in right when a big explosion or something happens in a movie, getting freaked out and running back outside. :D
jostenmeat
lsiberian
lsiberian
Where is the cocktail? :confused:
Nice looking table to beat on when that bad movie comes on and you need to get the frustration out.
tattoo_Dan
tattoo_Dan
there is no problem with any kind of noise or vibrations from it. :)
tattoo_Dan
tattoo_Dan
no! LOL,
she's an aussie
