0
08op
heres the best shot, this is what happens when your dog goes kujo mode and slams into the speaker stand
ParadigmDawg
ParadigmDawg
That dog hates your speakers.
Good job on the system, looks good.
W
westcott
Congratulations!!
Looks like you will be enjoying your system despite whatever the dog can dish out!!!
ParadigmDawg
ParadigmDawg
That dog is going to make for a good upgrade reason.
0
08op
yes she will. i'm trying to decide if i want mono or dipole for new surrounds when i get some. what suggestions do people have?and where to put dipoles if thats the choice?
Joeteck
Joeteck
You live on Long Island? SA cable box! Media room is no place for a dog...
jeffsg4mac
jeffsg4mac
Republican Poster Boy
Your center channel tweeter is dented in. If it is a replaceable type of diaphragm, you could take it off and pop it it back out.
croseiv
croseiv
LOL!!! I missed that one!:D Yeah, that should just pop right back into place.
adwilk
adwilk
Nice setup... Whatever you do for surrounds, I'd hang em up... kinda high...
0
08op
i'm guessing that was the mutts fault also????? how would it pop out just unscrew tweeter and the top cover type thing will come off???? any sugesstions on surrond speakers,what kind and where??? and where should i put "sound boards" to stop reflections? it's kinda bright in there. thanks for all the kind remarks, hopefully it'll only get better.
Adam
Adam
I said it in the other thread, but I'll repeat it here now that you've got your very own gallery - nice set-up! I like it. Cute pooch, too! I've been lucky that my pooch Niki hasn't gone "kujo" on my stuff, yet. :)
jeffsg4mac
jeffsg4mac
You would have to remove the tweeter, then look to see if it is the type that is easily replaced. It is usually held together with screws or clips of some sort. The tweeters face would come of then you could take off the diaphragm and replace it or pop back into place.
lsiberian
lsiberian
should i do side walls with dipoles or back wall with monopoles???and how high???
dipoles on the sides and mono poles on the back :)
But dipoles on the sides first. I'd say 2 to 3 feet above your sitting ear level which is around 36".
I believe in putting surrounds above kid reaching height. So I say 6 to 7 feet up.
