Some snaps of my build
One sub is done. Only aesthetic finishing and polyfill stuffing is remaining. Letting the silicon settle in in the other two subs. Should be up tomorrow.
I havent heard any subs before except during auditions. So this is my first sub
. Here is what I have tried. This time my connections were right. Placed the sub in the front next to the towers. But the volume on the sub was still low. I gave a 10dB boost at the AVR (Does the receiver also boost LFE by 10 dB, without running audyssey?). I get to hear it come alive slowly from about 40% - 50% of volume on Crown. About 60%-75% it starts to pound. Is this normal and expected? (Also, at times, it begins to distorts above 75%).
The sub is tight, and mostly accurate. It is far from being boomy. Sometime I hear it distort a bit, mostly at louder volumes. Maybe polyfill could help. So far it sounds really good. Thanks a lot for the build!!
However, i feel it lacks a bit in volume/punch. I could be mistaken here. When I tried the test tone from amp, for the sub it was playing a different tone (as expected), but the sub volume was way lower than the remaining speakers. A 10dB boost still didnt come to the loudness level that the fronts was throwing out.
here are a few snaps of the build.
There is a strip of rubber kind of material that came along with the driver, which can stick. It's length is about the circumference of the driver. Wondering what is this for? Should it sit between driver and the panel on which it rests?
