Muscial Home Theater Speaker Package < $900?
JK_Livin22
JK_Livin22
I'm looking for home theater speaker packages/systems to audition that are under $900 or so. They will be paired with an Onkyo TX-SR605. The size of the room is adequate for 5.1 to a 7.1 system. My primary concern is the musicality of the speakers. One of the options I am considering is the Infinity TSS-750; however, if I go that route I would like to add a pair of Infinity Beta 10s as the fronts (Beta 20s are too large for the area) which would make it a 7.1 system. The problem would be the continuity of the front speakers with the center channel.
Another consideration is the Definitive Technology ProCinema 800. Again, I would like to maybe add a pair 1000s as the front two, turning this system into a 7.1, although the same issue arises as to whether the center channel would sound cohesive being different than the fronts. I could just go with the ProCinema 1000 but I really don't think I need that powerful of a system.
I have read good things about the KEF packages but they are far too eccentric looking for the room they will be used in (they have to be approved by the woman of the house, which is the only reason that the fronts will be monitor/satellites or very small bookshelves.) Again, my main objective is to find the most "muscial" 5.1+ system I can find. Please spare me the lectures on how "muscial" is subjective and that I need to bring all the systems home and hook each of them up to my system and see how each sounds with my equipment and position just so in my room, etc., etc. That would be an ideal situation that is neither practical nor possible; so, I am hoping that I can get some input on some systems that are largely regarded as being very musical, in so much as any HT speaker system can be. That having been said, I am not absolutely convinced that a HT speaker is my best option and am therefore completely open to any other suggestions on how to accomplish my goal of having great sound from small conservative looking speakers under $900 (perhaps a next to impossible goal?).
Thanks in advance for your suggestions.
p.s. There are currently Klipsch satellites connected to the system. They are speakers that came with an inexpensive Samsung HTIB and the sub is non powered and has to be replaced. The other speakers could suffice as surround speakers, but I definitely would like something with better imaging and a better soundstage with cleaner mids for the fronts. This of course would require a new center channel as well. Help!!! :confused:
ChunkyDark
Here are a few suggestions keeping in mind smaller discret is better and ~900 limit:
Sub- http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=300-635
EMP onwall speakers from Audioholics.com
RBH WM onwalls from emptek.com
Infinity primus series. The 162 got good reviews and the 152 and lower can mount directly on the wall.
Polk RTia series.
That's all that's coming to mind right now.
abefroeman
abefroeman
If it were me, I would keep the Klipsch speakers as surrounds, buy a HSU STF2 subwoofer for $350 and get the best 3 speakers my money would buy for the mains/center.
For about $800 you can get an X-LS Encore 5.0 system.
From SVS, you could get a 5.0 or SBS or SCS package, though they are unfortunately out of stock until July.
I do agree with the Sausage King's ( ;) ) line of thinking though, and if it were my money I'd be doing something along those lines.
DD66000
DD66000
One problem with that is getting LCRs that timbre match the Klipsch, most likely have to stay with Klipsch, unless they were to be used only a short time and then replaced, with the same brand as the LCRs.
Timbre matching to the rears is usually not a big deal, though if the plan is for multichannel music, then I would say matching rears is a must. In this case however, you can upgrade the surrounds to match a little later on.
DD66000
DD66000
It is a big deal if the speakers are too far off timbre. I've got first hand knowledge of that, even with the same brand of speakers.
10 years ago I had three L55s across the front and a pair a of L212S for the surrounds. The timbre match was bad, so I built up the stereo L212 system to a 7 channel, buying the drivers off ebay and building the crossovers and boxes.
Yes, with Klipsch you could have a hard time matching them to something else, but I wouldn't let my surrounds drive the rest of my system. The LCR are the most important speakers, surrounds should follow that decision.
Warpdrv
Warpdrv
Nothing wrong with trying it for a while, while one would save some money for matched speakers in the rear.
Better to use up as much funds on a great matching front 3....
Worked great for me...
