Movies In DTS Master Audio & True HD
David Gaudreau
David Gaudreau
Lets start a list of movies in these Audio formats.
(Name Of Movie) (Blu-ray Or HD-DVD) (True HD or Master Audio)
1. Phone Booth-Blu-Ray-DTS-MA
2. Matrix-Blu-Ray-True HD
3. 300-Blu-Ray-True HD
4.
5.
6.
7.
8.
9.
10.
Matrix isn't on Blu-ray.
Kingdom of Heaven BD = DTS-HD MA
G
Gasman
As J said, Matrix is only HD DVD. Also 300 is HD DVD and BD.
To add to Jeff's post, another place is HERE and HERE
Bluesmoke
Every Fox Blu-ray has 24bit DTS Master tracks. So that's a lot to list.
Hi Ho
Hi Ho
The Bourne Ultimatum on HD-DVD has an amazing TrueHD track. The Perfect Storm and Constantine also have a TrueHD track.
Bluesmoke
Of course, the untouchable track is still Blackhawk Down on Blu-ray. That PCM track is mixed so hot and the speakers are so active that you forget you're in your living room.
Okay, there are a lot of movies in DTS-MA. But does ANYONE have a DTS-MA BD or HD DVD player yet (BD-UP5000)?
This is what you want: Pan's Labyrinth 7.1 DTS-MA, The Condemned 7.1 DTS-MA, Day After Tomorrow 5.1 DTS-MA.
The Sammy 1400 can also pass DTS-HD MA with a firmware update.
Bluesmoke
The panasonic BD30 passes True HD and DTS MA to your 1.3 receiver. It is also fully Blu-ray Java 1.1 ready, for those picture in picture titles coming up. If you're buying a standalone over the PS3, this is the one.
David Gaudreau
David Gaudreau
So wait a min, So if most DTS MA movies are only 5.1 does that mean 2 of my 7 total channels will be playing? I'm building a 7.2 Setup
If he has PLIIx engaged, all of his speakers will be playing, not just 5.1.
True, though I tend to leave stuff like that off. I don't have PLIIx anyway, and my setup is 5.1 despite the ability to do 7.1 :)
GlocksRock
GlocksRock
I see no good reason to not use it, unless you just don't like having sound coming from behind you. I don't find that it adds anything artificial to the sound, it just makes for a much more enjoyable experience, and makes the pans more smooth sounding.
As GlocksRock pointed out, while playing DTS-MA, TURN ON the Dolby ProLogic IIx Surround Mode, which will "Matrix" your Two Surround Channels into Four (2 side surrounds and 2 rear surrounds!).
EDIT: I will have SIX Surround Speakers and I don't even have Dolby ProLogic IIx.
That will not stop me from using my six surround speakers! I have actually thought about getting another CLR3000, although there are no such surround modes made for 2 Center speakers (not for consumer home theater). Is a 10.3 System too much?
Joe Schmoe
4.
5.
6.
7.
8.
9.
10.
What is the purpose of the list?:confused: I buy DVDs based on liking them as movies, not on what kind of soundtrack(s) they have!
For audioholics like us, there is no such thing as too much. I would put a trinity sub in every corner of my room if I had the space, and could afford it.
That is so TRUE-HD!
They don't call us AUDIOHOLICS for nothing!:D
