Monoprice Monolith 7 Amp "remote?"
O
ofcr17601
Can you operate with a remote? Remote not supplied. Called costumer support for PRONTO HEX CODES to check HTML files to see if it was compatible with harmony 1 and the rep didn't know what I was talking about and at least uninformed, he kept saying;"I think" or I don't believe.
Any info would be appreciated
BoredSysAdmin
BoredSysAdmin
It's just an amp. It doesn't any controls, besides (maybe) one time used input level adjustments.
Local or remote. If you looking to control something - you need a pre-amp or a pre-pro
What exactly would you need to control? It should have a trigger on/off and beyond that, most amps don't have any other things to control. If you don't see IR, RF, or RS232 then it doesn't NEED remote access (it is an amp....).
As you can see, it has a trigger input only on the back, nothing on the front but a power button:
Nothing for a Harmony to control, use a trigger or smart power strip.
O
ofcr17601
Hello,I discovered this solution on an earlier post. Unfortunately I don't know what the heck this means. I have the OPPO 105D as my pre-amp. Can someone explain it to me in laymans terms. I have a self assessed 8th grade education.
The Oppo has no trigger to remotely turn on an amp, but with a little reading I spliced a USB and mini mono jack cable together as the USB connections on the Oppo turn on and off with the unit.
O
ofcr17601
