For AV preamp processors, I won't mind spending 10-20 K on a 16 channel unit if I need the feature but also only if they actually use SOTA parts and components. Sadly they don't, ASR will be measuring one like that soon. For example, many of us agreed that most DACs are good enough, not going to be the audio quality bottle neck, but it is a matter of principle that for a > $10k unit, if they cheapen on a few DAC chips that cost less than $20 a piece even for the SOTA/top of the line ones, what else would they have done to cut cost?
For a lot of money, you get specs such as this:
Altitude 32
AUDIO PROCESSING
• ADC Resolution / Sampling Rate: 24 bits/96 kHz
• DAC Resolution / Sampling Rate: 24 bits/192 kHz
• A/D Signal-To-Noise Ratio: 119 dB (A-Weighted)
• D/A Signal-To-Noise Ratio: 118 dB (A-Weighted)
For the Altitude 16, you get:
- ADC Resolution / Sampling Rate:24 bits/96 kHz
- DAC Resolution / Sampling Rate:24 bits/96 kHz
So you can forget about playing DSD, not even the lowest DSD64. Seems like some dongle can do better.
I hate to say this over there, but pretty sure this thing won't come close to 100 dB SINAD, likely not even 95 dB if it was the Altitude 16.
If 11 to 13 channel processing is enough, nothing beats the value of Yamaha's and Marantz, or if balanced outputs are not needed then I would rank them by value as follow:
AVC-X8500H (for Europeans), AVR-X8500H, but only for <$3,000, Yamaha CX-A51/5200, with full warranty only, Marantz AV8805, AV7705/6. Ignore the rest, that's just my opinion (concerns with bugs and why pay more for less), but I did try my best to be objective about the ranking.
It does come with Trinnov, and that may be a compelling reason for the believers.
