Monitor Audio Gold W15 Subwoofer Overview
HTKamikazee
Audioholics Sheriff
Nothing like those chest pounding effects from low frequencies. Just in case you didn't know, Monitor Audio has launched their newest new line of Gold speakers. They also launched a new powerhouse which will be in charge of handling the hard and "dirty" work, the deep bass notes and chest impact we all crave for. Meet the new Gold W15 Sealed Subwoofer!
They have installed an ultra-long throw 15″ C-CAM bass driver, triple suspended for a full 1.5-inch of linear excursion. Featuring a massive magnet structure and under the control of a 650W D2 AUDIO DSP controlled amplifier, this deep bass generator will be in charge of delivering a new dimension to bass, high SPL, dynamic control and headroom. According to the company, the Gold W15 is capable of hitting down to 18Hz with "brute force", but it is also an intelligent design, featuring an advanced automatic room correction system called LEO™ (Listening Environment Optimizer). LEO simply and automatically eliminates the detrimental bass boost of boundaries and corners through the use of a microphone and test tones.
So, there you have it. If you are looking for a new sub, make sure you check this one out before buying. It just might be the one you need. Share your thoughts with us!
FEATURES:
  • Ultra long throw 15” C-CAM® (Ceramic-Coated Aluminium/Magnesium) driver featuring triple suspension
  • Large black anodized 3” voice coil and double stack motor system provides high power handling and low distortion
  • Carefully optimized motor system design to reduce heat and improve efficiency
  • Powerful 650-Watt DSP Controlled amplifier (D2 Audio™)
  • Advanced full bridge switch mode power supply (SMPSU) Capable of delivering over 1200 watt peak power
  • 12V trigger - provides switching control from A.V amp or processor
  • Rigid, 25mm (1”) thick M.D.F construct
  • Heavy radial cabinet bracing with separate amplifier partition
  • Front mounted control panel for easy access and viewing
  • The LEO™ system provides Automatic Room Mode Correction (ARMC) for easy set up and perfect sound quality
  • Remote control with 4 user EQ settings
  • Selected real wood veneer or high gloss lacquer finishes
SPECIFICATIONS:
  • System Format: Sealed Cabinet. 25mm M.D.F construction with internal bracing. Sealed amplifier compartment
  • Low Frequency Limit: 18 Hz
  • Upper Frequency Limit: 40 - 120 Hz Variable
  • Low Pass Filter Alignment: Active 4th order 24dB/octave (6/12/18/24 dB user adjustable)
  • Amplifier Power Output: 650 watts Continuous. 1200 watts Peak
  • Amplifier Classification: D2
  • Audio DSP controlled, Class-D amplifier system. High current switch mode power supply (SMPSU)
  • Equalization: 4 Settings (Off/Music/Movie/Impact)
  • Phase Control: 0-90-180-270 degrees
  • Auto Sensing Input Level Requirements: Line Level > 2mV. Standby after 10 minutes if no signal sensed
  • Digital Volume Level: -60 to +10dB in 1dB increments
  • Drive Unit Complement: 1 x 15” C-CAM sub-woofer driver featuring triple suspension, 3” long throw voice coil
  • 12V Trigger Input: 3.5mm mono jack socket
  • Connections: Stereo RCA, 12V Trigger in (3.5mm mono jack), 3.5mm Microphone input jack (microphone supplied)
  • Input Impedance: 20 K Ohms
  • Dimensions (HxWxD): 430 x 400 x 400 mm
  • Grille Depth: 28 mm
  • Weight (unpacked): 77lb. 10oz.
  • Mains Input Voltage: 100 - 120 Vac / 220 - 240 Vac 50/60 Hz (Factory preset)
  • Electrical Certifications: CE/CB/ETL/Fcc/ErP (Energy saving compliant)
  • Power Consumption: Maximum 1000W. Standby < 0.5W (ErP Compliance)
  • Fuse Type: 20mm UL/VDE (Value is region specific)
  • IR Remote Control: Yes
PRICE: (Standard Finish): $3,695 each / (Piano Ebony Finish): $4,395 each
BoredSysAdmin
BoredSysAdmin
Great looking sub, but at this price point one should be looking for ether Funk or if looks matters less, at pair of JTR Captivator 1400's
