Monitor Audio Bronze Centre (Center Channel) Overview
HTKamikazee
Audioholics Sheriff
Most people consider the center channel to be the most important speaker in a home theater system and Monitor Audio knows this. That's why they keep innovating and pushing the envelope with their Bronze Centre.
This speaker has been designed to be the perfect match for the Bronze left/right tower speakers in a home theater LCR array. The Centre features twin 5-1/2” C-CAM® bass/mid-range drivers straddling a Bronze C-CAM tweeter for pin-point synergy with its satellite partners producing seamless front soundstage action and articulate dialogue.
If you haven't heard a Monitor Audio speaker in action, maybe this is the time to schedule a visit to your nearest audio store. As of today, I have not been disappointed by any of the products I've tested. So, yes; I'm expecting good things from this one as well. Take a look at the following features and specifications. What do you think?
FEATURES:
  • Dual 5 1/2” bass/midrange drivers with concave ‘dished’ C-CAM® cone profile
  • Acoustically matched to Bronze speaker systems for excellent imaging and consistency of timbre in surround applications
  • Single bolt-through driver systems, for increased overall bracing, rigidity and driver/baffle de-coupling
  • High quality crossovers with premium grade Polypropylene film capacitors used throughout
  • Rigid 18mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet coloration
  • Invisible magnetic grille fixing
  • Premium quality vinyl veneer finishes
SPECIFICATIONS:
  • System Format: 2 Way
  • Frequency Response: 60Hz - 30kHz
  • Nominal Impedance: 8Ω
  • Maximum SPL (dBA @1M – each): 113dBA
  • Power Handling RMS: 120W
  • Recommended Amplifier Requirements: 20-120W
  • Cabinet Design: Sealed Cabinet
  • Drive Unit Complement: 2 x 5 1/2" C-CAM® bass mid-range driver.
  • 1 x 25 mm gold dome C-CAM® tweeter
  • Crossover Frequency: 3.0kHz
  • Cabinet Dimensions: (H x W x D): 6-1/2" x 18-1/8" x 6-1/2"
  • Complete Dimensions including grilles & terminals: (H x W x D): 6-1/2 x 18-1/8 x 7-5/8 inches
  • Weight (Individual): 12 lbs. 6 oz.
