Even though Klipsch is fairly well known for exaggerating their sensitivity numbers by a few dB, you don't need a lot of amp to get very loud with these speakers even with that in mind (also keep in mind it takes a doubling of power to gain merely 3dB of spl).
However, they do seem to spend some time at low impedance, see the test results
here, so if you plan on using these at their upper limits on an ongoing basis perhaps you might look for a receiver that's rated for 4ohms (some aren't and at high leve
ls could conceivably cause the receiver's self-protection mode to trip).
Amp is more based on use rather than the speakers alone. Just what spl levels are you planning on?
Have you used an spl calculator? Is this a stereo setup or are other speakers being driven?
