Mixing HDMI Versions
rnatalli
So, I have an EMO UMC-1 on preorder and preparing to buy an HD-capable projector; but I admit my knowledge of HDMI and new formats is limited to none. I have some HDMI cables, but not sure if they play nice together. I have 1.3a cables to run from the sources to the pre/pro and a 35ft 1.2a cable to run from the pre/pro to the projector. Is it a problem that the sources are being fed via 1.3a and the video going to the projector is over a 1.2a cable? Or do I need to buy a new 35ft. 1.3a cable?
E
EJ1
As far as I know, an HDMI cable is an HDMI cable. Putting a version on the cable is just a marketing gimmick. It's all digital.
jostenmeat
+1. As far as the cables, its rated as far as tested bandwidth. If you can find 1.3 for the length you are looking for, by all means. I am using a non 1.3 rated 35 Monoprice HDMI cable. Its probably 1.1. That doesn't necessarily mean it could not pass a 1.3 test, but it wouldn't surprise me if it couldn't. I believe the rated bandwidth difference is about double. Pic is gorgeous, I see no need to change it out. I think its about $40.
Lot of reading, but your answer is there:
http://www.bluejeanscable.com/articles/certified-hdmi-cables.htm?hdmiinfo
The Myth of "1080p Certification":
As a result of this sort of anxiety, we get a lot of questions from customers about whether our HDMI cables are "certified" for 1080p. It's a natural question, especially given that if one shops around for HDMI cables, one will find a lot of cables which are said to be certified for 1080p. The answer to the question, however, is one that no one expects: our HDMI cables aren't certified for 1080p, nor are anyone's; there's no such thing as official 1080p certification.
and:
Now, there's a complicated sort of "kicker" here. The HDMI Adopter Agreement specifies that compliance testing is required only for a manufacturer's first product in a product category. So if one is a manufacturer of cable, all that has to be done is to meet compliance testing, once, for a single batch of cable. After that, no external compliance testing is required by the HDMI Adopter Agreement. One can build, for example, a 3-foot long 24 AWG cable with PE dielectric and bare copper conductors, have compliance testing done on it, and then go on to build a cable of a completely different length and design--say, a 25-foot long polyolefin dielectric cable with 28 AWG tinned copper conductors--and do no compliance testing at all. The HDMI Licensing organization has taken steps toward changing this situation, and has inserted into the Compliance Testing Specification some language indicating that a cable cannot be deemed "compliant" and therefore eligible to bear the HDMI trademarks unless it's been shown compliant up to the length being sold. However, these provisions presently are probably not enforceable because they squarely conflict with the Adopter Agreement, and they are routinely ignored.
