sparky77
Whats the best media player for keeping the correct aspect ratio with out getting black bars all the way around some ratios?
My computer setup is an old p3-700 running Windos XP with an Nvidia Geforce 5200fx connected to a Hanspree 28inch via dvi to hdmi adapter.
BoredSysAdmin
BoredSysAdmin
This is a a very, VERY old pc you got there, but If I were you - I'd try a couple of things and try to the DxVA gods out there....
Update to win xp sp3 if you haven't done it yet, latest Nvidia catalyst driver.
Get newest MPC-HC (I love SVN (dev builds) ) - from here:
http://www.xvidvideo.ru/media-player-classic-home-cinema-x86-x64/
Make sure to use video output to regular overlay.
And like I said before pray to gods that your DVDs will play using DxVA
http://imouto.my/watching-h264-videos-using-dxva/
P.s: MPC is highly customizable and it'll give you good amount of image resizing/aspect ratios and scalling
jinjuku
jinjuku
Moderator
Not going to happen. That monitor is a fixed resolution panel. You either send it 1900X1080 or you don't.
Your CPU/Video Card is so old as to most likely only support VGA/SVGA/XVGA resolutions
BoredSysAdmin
BoredSysAdmin
Partly true, but while the resolution is fixed, mpc still can scale and overscan to eliminate black bars
sparky77
What I figured out so far was to set the flat panel as the primary display and use full screen in Windows Media player, and the picture looks perfectly fine.
jinjuku
jinjuku
Moderator
I could see DVD playback looking acceptable with a 28" display since the GPU is going to internally scale the video but you could get more out of it by getting that panel driven at it's native resolution.
I don't know if I would try that with my 100" screen.
