Measurements not Revealing Significant Differences Between AVRs and AVPs
As you know my Marantz AV 10 has revealed a significant improvement in SQ over my 7705 and 7706.
A year or so ago, I bought a 2 BD Atmos disc set for the BPO, it was to highlight their prowess in Atmos production.
When I played the discs on my Marantz 7705 I was very disappointed. The sound was weak and not "immersive" at all. Now the same programs were available to stream in Atmos from the BPO. The stream was significantly better than the discs.
So I put the discs assides as duds. I don't think I ever played them on the 7706 and I only had that for 3 months.
Anyhow last week just for kicks I got out those Atmos discs. I had to think hard were I had put them, as I did not think I would play them again.
However when played back via the AV 10 the sound was absolutely spectacular, exciting and true to life.
Now I don't think there is anything in test results from these units that would give a hint of this dramatic difference in sound and presentation.
Now Dolby Atmos is streamed in Dolby Digital Plus and the discs Dolby True HD.
So, it seems that the 7705 was incapable of properly decoding Dolby True HD at the very least.
This came as a surprise to me. I note that there has been discussion about this on Audio Science Review and Amir has called the situation a total mess and I would agree.
So, I have to report that there are huge differences in SQ between devices you would not expect from specs and even reviews containing standard measurements.
I can tell you Lovin, that the 7705 could not decode those discs correctly. The Atmos was way inferior to the stereo track, but the AV 10 produced glorious and ambient full bodied sound. We are talking about a massive difference here and not a minor one. On the 7705 the Atmos track was essentially unlistenable. So the processor was clearly not up to the task.
By far the biggest difference between the AV 10 and the others is playback of Atmos streams and discs. It is a huge improvement. it is clear to me that the others did not decode Atmos content optimally and was way wide of the mark. I suspect most AVRs do not, at least Marantz and Denon. This is not a splitting hairs difference but huge and unmistakable.
Out of curiosity, at what volume level?
I generally play back at concert level. However, both the AV 7705 and 7706 played back Atmos streams at least 10 db. quieter so that the volume had to be significantly advanced for the Atmos streams. On the AV 10 the stereo and Atmos streams play back at the same level.
But the big issue is that the perspective of the sound stage is totally different. The AV 10 reproduces them like the concert hall with realistic positioning of the players left to right and front to back. The orchestra is set back behind the screen and sounds as if it is on stage. I am absolutely stunned at how realistic the sound stage is. The 7705 and 7706 did not come close to that. With the audience applause it surrounds you, whereas before it was all up front and it did not sound as if you were surrounded by the audience.
I have to suspect that this is all related to the increased power of the DAC in the AV 10. But before and after is not close to comparable. This is all unfortunate, as it means that at the current time, you need high end units to optimize Atmos playback. However technology has a habit of filtering down. I suspect overtime Atmos playback is likely to improve at the mid to lower end of the market.
I never thought I would have to spend as much as I did to get a decent processor. I only did as the 7705 and especially the 7706 had short lifespans and therefore were a problem and bad value for money. I like gear that has "long legs" and by most of my purchases have had, with gear over 60 years old in regular use.
I have no tolerance for gear that blows up in a few years and certainly not in a few months like the 7706.,
