I can't remember the last time I saw a truly versatile speaker like the one I'm going to talk about today... The EM-FX2 Speaker.
As part of the ElectroMotion Series, the EM-FX2 Speaker is voice and timbre matched with the rest of its line. This nice speaker features not one, but dual Folded Motion XT tweeters in a wide-dispersion array making it ideal for surround applications.
According to MartinLogan, the Folded Motion XT tweeter boasts a radiating surface 40% larger than those found in their award-winning Motion® Series products. I don't know how many of you have heard the XT tweeter in action, but let me tell you that it is one sweet tweeter. Low frequencies are managed by one 6.5-inch doped fiber-cone woofer. For best convenience and versatility, the FX2 can be mounted on corners, walls, or angled-walls. Take a look at the specifications and let us know what you think. I don't know about you, but I like these babies... a lot!
SPECIFICATIONS:
- Frequency Response: 55–25,000 Hz ±3dB.
- Dispersion: 160° x 30°
- Sensitivity: 93 dB @ 2.83 volts/ meter.
- Nominal Impedance: 5 Ohms. Compatible with 4, 6 or 8 ohm rated amplifiers.
- Recommended Amplifier Power: 20-200 watts per channel.
- Crossover Frequency: 2,300Hz
- High Frequency Transducer: Two 1.25" × 2.4" (3.2cm × 6.1cm) Folded Motion Transducers with 4.5" × 2.75" (11.4cm × 7cm) diaphragm.
- Low Frequency Driver: 6.5" (16.5cm) paper cone with cast aluminum basket. Ported.
- Weight: 16lbs./each
- Overall Dimensions (HxWxD): 14.9" x 14" x 6.8".
Price: $649.95/each
