Ditto the Denon. It matches up well with my Klipsch speaker system. The auto setup function is really pretty good (assuming the 2805 works the same way as my 3805). It gets distances spot on and channel levels are set 95% the same as using an SPL meter....I used both, just because
The built in equalizer, when using the auto setup, is something you can't really do with a SPL meter...at least not as easily. Either way, it's a pretty nice receiver.
So why DID you buy Klipsch if you thought they were too bright???? Myself, after fourteen + years listening to various Klipsch speakers in my HT, I don't find them bright at all.......everything else I've auditioned is dull
Mort
