Marantz SR7009 issue with crosstalk rear surround and sub
N
Niklasmagnus
I notice a strange issue when checking the Levels settings for my 7.1 set up. When testing levels on rear surround I also get the noise sound from my subs. Same with both left and right rear surround channels. There is no cross talk with any of the other channels.
I run all surrounds (“normal” and rear) on a 4 channel amp.
All 7 speaker are small and crossover at 100 Hz.
Could some one test if they have same with rear surround (or other channel) so I know I the receiver is broken?
Thanks
N
Niklasmagnus
I have now tried following:
Test 1-4: Sub 1 pre-out in use
  1. Surround amp off
    Surround speaker set to Small
    Crossover 100Hz
    Result: Still noise in sub when setting level for rear surround channel
  2. Surround amp off and disconnect all cables to power amp
    Crossover 100Hz
  3. Surround amp off
    Surround speakers set to Large
    Subwoofer: LFE
    Result: No sound I sub
  4. Surround amp off
    Subwoofer: LFE+Main
    Test 5- : Sub 2 pre-out in use
  5. Surround amp off
    Crossover 100Hz
    Result: No sound I sub :)
Something is wrong with the sub 1 pre-out. Since I run the sub signal via a minidsp I don’t really need both 1 and 2 pre-out so I can live with this issue. I could try to have it fixed by a local guy I know but it’s always a risk something else goes wrong, so I think I just let it be.
