Marantz SR7001 1080P video problem
PHANofPHUNK
PHANofPHUNK
How in the world do I get this thing to pass 1080p video??
I am using 1.3 hdmi cables from a bd player, to the sr7001, so I dont think thats the problem. And also to the tv...
Is it the fact that the SR7001 only outputs hdmi 1.2??:confused:
thanks in advance..
Michael
bandphan
bandphan
Have you updated the firmware? There were some video issues with the 01 series.
PHANofPHUNK
PHANofPHUNK
Firmware ehh?
I have not, ever. I check Marantz.com for them but only see dl for the manual, spec sheet, etc.
Do have a link?
bandphan
bandphan
Do have a link?
Call Marantz, think the 01 series needs to be done by service center:eek:
-open the front panal of the 7002
-Hold down the pure direct button,the 7.1 input button and the M-DIX button at the same time(for 2-4 seconds)
-then press the enter button on the front panel,it will give you numbers
-press again 2 to 3 more times and it will show you your version
Rudy Langstraat
The SR7001 works perfect at even 1080p24!
thanks in advance..
Michael
I am using 1.3 Hdmi cables also and it works perfect in combination with my Marantz BD5004. I have the BD5004 since a few weeks now and it is a great combination. Before I have used a Marantz DV6001 which also works great but isn't Blu-Ray of-course;).
I didn't need to upgrade any firmware to make it work.
Where did you connect your HDMI cables into:confused:?
Did you know the BD5004 is able to upgrade normal DVD to 1080p which is a great option.
In case of a Blu-Ray disc it is even possible to play 1080p24.
Or with a CD it is possible to play in pure Direct-Mode.
That's all real quality people!
Regards,
Rudolf.
