Hello,
I have a marantz sr-18u in need of repair. It has been down a while, I bought a marantz 7200 as a replacement in order to send it out, buy never did. I now am having problems with the 7200 which I will send out under warrenty, but I would also like to get the sr-18u fixed if possible.
I am getting no sound out of the unit. I used the tuner and well as a marantz cassette deck to test.
I have attempted to connect a marantz mm500 amp that I have from when I used an av-500 preamp (which I no longer own) to the preouts and still get no sound. I am not really sure what I am doing, but I removed the jumpers from the mains prein/preout and I connected the amp, and assumed that it would use the external amp without changing any settings, but I am not sure if thats correct. I connected the amp with standard high quality rca cables, is that correct? Could someone suggest a better way to determine the problem?
As such I am not sure if its an amp problem (which I assumed it was) or something else. Does anyone have an idea what might be wrong and if the mm500 amp should have produced sound? Any suggestions as to the best person to repair this unit and what might the cost be? I am on the east coast so if possible I would prefer to send it as short a distance as possible.
Bill Mann
