Marantz PM 11 S3 sound seems low when compared to Marantz PM 8006 or PM 6007
sabu
Hi,
Marantz PM 11 S3 sound seems low when compared to Marantz PM 8006 or PM 6007, the input is from SA 11 S3
Pogre
Pogre
Wut?
You sir, are going to have to be a little bit more descriptive of your issue! Based on what you gave us to work with I'd say turning up the volume dial should solve your problem...
Hi,
Check your settings. How are you connecting the SA 11 S3 to each, RCA or are you using the XLR inputs on the PM 11 S3?
"low", meaning what? Not as loud, less treble...?
sabu
...Low means not as loud....am using XLR cables...i kept balance as LR- 0 0 . Treble at 8 and Bass at 4 or 6. There is no other adjustments in volume control
sabu
I tried three kinds of XLR cables, CHORD, PROEL and Thrown max...RCA also tried
Why would it be a cable rather than just a gain structure difference? How are you comparing the output? Hopefully not a volume dial position....
