Marantz NR1510 front usb
StanUbeki
I am trying (unsuccesfully) to play mp3s using the front usb port. It understand is limited to 32 gb, no adapters. I am using a straight up 16 gb usb stick. I'm tied to a brand new LG OLED TV with Web OS and the Marantz smart menu works. I updated the firmware on the Marantz and the LG. I can navigate the folders and files but when I hit play it says "network not connected". I know my network is working, it streams radio stations and tv. Why would the network be needed for a direct connection to the usb port? I'm fairly savvy with this stuff but no way can I make this work. Also, I would hope that a 2019 unit with an earc HDMI port would have better usb implementation. Anybody?
KEW
KEW
Check the setup menu for inputs.
Somewhere in the menu system, you switch the active USB between the front and back USB connector.
AT least, that is what I needed to do on one of my D&M AVR's
I'm sketchy on details, it has been awhile since I did this!
Oh, and welcome!
Edit: I just reviewed the back panel of your AVR and do not see any USB ports, so the above will not apply.
Do a factory reset (just in case).
Plus just one thread is sufficient....but like the reset idea.
