these amps are sold!
these are actually MA6100s not MA500s, the specs are the same for both models I just listed the incorrect model number. The MA6100s model replaced the MA500s
$450.00 obo plus shipping
This ad is for Four Marantz MA-500 THX Ultra Monoblock amps. 125 Watts into 8 Ohms, 180 watts into 4 ohms. The LED's do work, Red when in StandBy and Blue when On. These amps can also be setup to switch between "on" and "StandBy" with a Video Source from your receiver / PrePro or from a DVD player. These amps are stackable. I had these amps in a cabinet of their own along with the pair of MA700's I recently sold but recently took them out in preparation of getting my new amps and new component rack.
I am currently using these Four amps for my Center, surround and surround back speakers but I will be upgrading. I bought these from a friend of mine about 6 months ago, he was the original owner and used his system casually. I like the amps but I am upgrading to Anthem multi-channel amps. I would prefer to sell the four as a package but I am willing to sell them in Pairs ( $250 for two )
I do not have the original boxes but I will have them professional packaged.
You can check my feedback on ebay as well( ts108 )
Model description below.
MA-6100
Amplifier Section
Continuous power output (RMS)
8½ 20 Hz - 20 kHz 125 W
Total harmonic distortion <.05%
4½ 20 Hz - 20 kHz 180 W
Total harmonic distortion <.09%
Bridged mode (2 x MA-6100)
8½ 20 Hz - 20 kHz 360 W
Total harmonic distortion <.1%
Damping factor at 8½ 200
Frequency response 1 W 10 Hz - 100 kHz ± 1 dB
S/N ratio 116 dB
Input sensitivity/impedance 1 V/30 k½
General
Power requirements 120 V, 60 Hz, 230 W
Dimensions W/H/D 3 5⁄16” x 5 1⁄2” x 17 3⁄4”
84mm x 140mm x 451mm
Weight 14 lbs. 6.4 kg.
http://www.marantz.com/pdfs/u_amp_ma6100_bck.pdf#search='marantz ma6100'
