Marantz Cinema 30 AVR to Replace the SR8015
I would bet the C30 will measure as good as (or a touch better) the SR8015 that have the AKM dac chip, but better than those that have the TI chips. It won't do much better because aside from the slighly better dac chip (vs the AK4458), the rest appear to be practically the same. The new ones all have better dsp chip, and the option to use DLBC is one feature that the SR8015 and AV8805 cannot beat.
Deckard71
I have been with the C30 one week and so far it is amazing. Very clean sound, maybe less warm than my previous Marantz but very pleasing sound. Stereo sounds superb
Congratulations! Imo you picked a winner!
The thing I really like about the Cinema 30 is that it has dac filter options 1 and 2, just like the much more expensive AV10. So, both believers and non believers of the so called Marantz sound can easily AB the two and settle with the one they perceive as better. No more forum debate needed on that lol.. The other thing is, of course, those who are keen on getting the best possible DAC IC (me included) finally got their wish, no more mediocre dac chip used in the models below. If I hadn't bought my AVM, I would have seriously considered the C30 too as I don't need 15 channels, room is too small for that anyway.
Paul McNeil
One question I have, does the AV10 (full disclosure, I own one) offer any advantages over the Cinema 30? Or, put another way, AV10 or C 30, with a separate power amplifier for the L/R? What's the current thinking on top-of-the-line separates (like the AV10) versus receivers (like the C 30)?
Paul McNeil
The thing I really like about the Cinema 30 is that it has dac filter options 1 and 2, just like the much more expensive AV10. So, both believers and non believers of the so called Marantz sound can easily AB the two and settle with the one they perceive as better. No more forum debate needed on that lol.. The other thing is, of course, those who are keen on getting the best possible DAC IC (me included) finally got their wish, no more mediocre dac chip used in the models below. If I hadn't bought my AVM, I would have serious considered the C30 too as I don't need 15 channels, room is too small for that anyway.
Yeah, I have this choice on my AV10, Peng, but the unfortunate thing is, I'm old and don't hear much above 10k. But still I use filter 2 (no Marantz diminution of the highs, maybe someone listening in my home theather will benefit, of course, the REW measurements look better!).
Bragging rights, even better (State of the Art) measurements than great measurements. :D
The other factor is which amp are you using with your SOTA-AVP? Are you using an equivalent SOTA-Amp?
Paul McNeil
I have no idea if I'm power amp 'SOTA'! My power amps are NAD M25 (seven channel, for surrounds only six used), McIntosh M347 (seven channel, for center, and four other atmos surrounds, only five channels used}, and a Cary Cinema 5 (for left and right fronts, only two of five channels). I aim not to tax any of any of these, for example power supplies.
For real world use, the Cinema 30 should be just as good if you don't need the additional features the AV10 offers, such as:
- 15 channel processing vs only 13.
- Reference class DAC IC, vs the C30's "premier" DAC, but I am sure there will be no audible difference between those ICs.
- Balanced inputs and outputs.
- Better build quality, in terms of boards layout, shielding, better isolation, more power supplies for various parts to minimize interference.
Other resulting electrical/physical advantages from being separated from the heavy current power supply used in the C30 for the power amplifier section.
On money no object basis, the AV10 would still be my choice if I don't want to use an AVR, but for people who want to save some money, and/or want to use the C30's build in amps for the surround and height channels, then the Cinema 30 is probably the best choice out there.
Paul McNeil
Well, I'm hoping the build quality will make this my last AV purchase!
NAD, McIntosh, and Carry Audio (made by ATI) amps are usually SOTA.
So ya passed. :D
Verdinut
Verdinut
So ya passed. :D
Monoprice's Monolith amps are also made by ATI. Are they also SOTA, if not then aren't they certainly close?
It depends what part of the device for such consideration, the whole thing, or just the design, of certain parts, circuitry, physical layout, shielding from interference, thermal control, specifications verified by bench measurements etc.
Complicated, but simple enough if we only consider specs and measurements. On that count then none of McIntosh, Cary Audio, ATI have such products, NAD does but only their Purifi, or may be certain Hypex based class D amplifiers.
McIntosh's would come close by all counts, but for one, their damping factor spec kind of suck, good enough for transparency, sure, but SOTA implies something that is head and shoulder above the normally accepted threshold.
As PENG says, perhaps not "SOTA" for most amps.
But I should have said "Prestigious high-end brands", not SOTA.
ATI, NAD, McIntosh, Cary Audio, Anthem, Krell, Bryston are examples of "prestigious high-end" brands to me.
W
WVO
Hi,
I use the SR8012 with a setup 5.0.2
Kef R series (not the meta) speakers with front bi-amp mode with height 2 in use. So think 9 channels in use. I am considering several upgrades.
A sub KC62 or KC92.
Or an amplifier Marantz MM7025 2channel for the fronts for more power.
Or perhaps the MM7055 5channel for the fronts and surround L/R in bi-amp?
Or should I buy the cinema 30 because the cinema is that much better?
silentshutters
Hi,
A sub KC62 or KC92.
Hi WVO,
Like you, my HT system has a Marantz SR8012 at its core but with more speakers in a 7.1.4 configuration.
About 6 months after getting the SR8012, I added a second hand Marantz MM7025 to power the mains. This was to help take to some of the amplification load off the SR8012 as I was running maximum permitted channels. It has helped a bit, and is noticeable in both 2 channel and HT modes.
My current planned upgrade is to add second bigger sub as my current sub is not powerful enough for the room size on its own.
Personally I think getting one or more subs (depending on room size/budget) to add extra dimension for LFE would be a good upgrade for your current setup, especially if cinema is a focus.
Is your current setup struggling with amplification from the SR8012? Then adding one or more power amps could be considered.
While I would like a Cinema 30 - who doesn't like upgrades - I don't need one as my current AVR's functionality and amplification is very good. The SR8012 delivers all that I need from an AVR for my usage.
W
WVO
Hi WVO,
Hi silentshutters,
I'm very late with a response, been very busy but continued my search and also looked at the option you indicated of an external amplifier. No SUB purchased yet, no time to listen yet. Did make time for a listening session Marantz Model10, SACD10 and LINK10 with B&W 801, far out of reach but fantastic. Took the gamble without listening and used the 20% holiday discount from Emotiva to purchase a BasX A5. Now in use for a week and connected 9.1 BiAmp, with the fronts BiAmp on the SR8012 for stereo listening and two dolby, center and surrounds connected to the BasX. This is a world of difference in audible details and bass response. Next step listening to SUBs.
The SR8012 stays.
