What if he were to now simply swap out the Marantz and put back his Anthem AVM 30 under the same exact conditions?
If the AVM 30 has the same noise issues, then the Marantz is not at fault.
But if the AVM 30, under the same exact conditions, is 100% silent, then what?
I am sure TLSG will take care of your question.  Today I did an experiment on my rack that has the following hook up to one dedicated 20A and 1 dedicated 15A cct.
1 HDDVDP, 2 BDP, 1 PS3, 1 XDE500, 1 Denon DVD3910, 1 router, 1 switch, 1 PCUltra, 1 Adcom GFA555, 1 Marantz MM8003, 1 Marantz AV7005, 1 external computer cooling fan, 1 pair of rack lights, 1 Bell 6131 HD receiver.  All powered by 1 dedicated 20A outlet and a 15A outlet.
1.  With the GFA555 powering the L/R, the MM8003 powering the C, SL, SR, SBL, SBR, hum is only barely audible at 0 with ear within an inch or two from the mid bass driver and hiss barely audible at 0 also with ear within an inch or two from the tweeter.  At -5, all is almost inaudible.  This is for the L/R, the C seemed quiet.
2.  Because the C was quiet so I reconnected the L/R speakers to the MM8003, now the hum is inaudible at 0 and seemed to be audible at +18 but I had to listen hard for it.  The hiss was almost completely gone even at +18, certain silent at +5.
3.  The SBL/R have virtually no hiss but always a hum that is audible only if my ears are within a couple of inches from them.  The cables for the SB are about 35 to 40 feet long.
None of the above surprise me because as TLSG said, these double insulated stuff are not grounded so their each and every chassis are going to have their own and different potential and the so called ground loop (a misnomer as there is not real ground as such) currents are going to be there.  So what happens then it that any hum you get will be dependent on the potential of the so called ground of each piece of equipment hooked up to the system.  In my case, the two Marantz must have very similar ground (again not true grounds) potential, hence virtually no hum.
Hiss is a different story, it is more of  an electromagnetically induced types of noise.  How bad it can get will depend on many things, including the kind of wires (shielding), connectors, length, path, interference between wires, equipment that emit electromagnetic field, among others.
You can eliminate or at least minimize hums if you can equalize the potentials of all of your equipment chassis/frame ground and keep the speaker wires relatively short, but it would be hard to eliminate hiss completely if you have long runs of speaker wires.  I would think that for most home systems, all these are moot point because such hum and hiss are only audible if your ears are part of your speaker's grille and when the volume is well beyond the level that you could tolerate.  I have reason to believe only people such as you, TLSG, AK and I would bother trying to eliminate such low level noises.  And I am guessing that most normal people won't even notice such noises.  Me, I can tell you how each of my amps transformer sound and that's with nothing connected, just the hum of the transformer itself.  I am sure you know the bigger the transformer, the louder it gets..
