Hi! So I have a Hifi rose 130 hooked into coax media player input of marantz av10. All music plays fine up till 92khz. But 192 flac no sound.
I’ve played it through Roon and directly through the Hifi rose and no luck.
Any ideas? Both fully updated
And I tried Qobuz 192 through my naim headphone amp and it plays perfectly. So it has to be the marantz or the hi fi rose
I can't find a spec for that RCA digital input, but you are operating right at the limit of a digital RCA connection. I note Marantz only specify the HDMI and HEOS bit rates.
One thing to make sure is that you are using a 75 ohm RCA cable and not an analog 50 ohm cable, otherwise you might get enough internal reflections to prevent it working.
However the issue is mute, as there is absolutely no point in using those sort of data rates. It is pointless and a waste of bits. The CD spec of 16 bit 44,1 Hz was perfectly and correctly chosen. That gets you are perfect FR out to 20 KHz, which is the limit of human hearing. It gives you a 96 db dynamic range which is enough for any domestic situation.
In mastering there is some benefit to give more headroom before running out ot bits. Then in production producing the final at 16bit 44.1 is absolutely no loss at all.
These high resolution streams are just another item in the long list of audiophoolery.
