mapleshade speaker cable
F
freefall-fast
<font color='#000000'>Looking to upgrade my current speaker cable(currently MIT T-2 bi-wire) on my Paradigms 60v2, not getting the sound that I think I should. A fellow Audioholic sent me a link for mapleshaderecords.com. Has anybody used the mapleshade speaker cables?
Thanx
freefall-fast</font>
G
Guest
Guest
<font color='#000000'>I have in my system both mapleshade speaker wire and one set of interconnect between my ATI 1502 amp and tube preamp. &nbsp;In all fairness they perform to my expectations and the science behind the product is audiophile tested. &nbsp;I would say you get great value for you money. &nbsp;Mr. Sprey will let you do a trial and knows his subject since he's a engineer formally with industry. &nbsp;If you want trueness to music and accuracy then mapleshade deserves a try. &nbsp;Connie</font>
gene
gene
Audioholics Master Chief
Administrator
<font color='#000000'>Freefall;
Before investing money in new speaker cables, you may first wish to address the following issues:
1) Speaker positioning and placement
2) Room acoustics
3) Listening position
Optimizing these parameters will have a far more profound impact on sonic improvments than expensive cabling.</font>
