M&K 12" woofers, Who's got em'? MX-100 repaired but still not working!!
  • Thread starter Thread starter Seth=L
I'm pretty sure it's not a counterfeit amplifier, I am fairly certain it's just a bad repair. As I mentioned before the subwoofer worked great for many months before an extreme circumstance caused it and my Carver amp to both shut off. Only difference is the Carver came back on, the M&K did not. After the repair the subwoofer was ran for a day and it fried again (due to improper fuse size) and they "repaired" it again. That time they put the correct fuse value in, but it was still sensitive enough to blow without much output comparitive to the first time it blew.
Replacement M&K 12" subs available
Electro Mavin has a drop in replacement for the M&K Subs. Compared to to the M&K 17035 driver the Mavin 12" Woofer handles a bit more power and is more efficient than the M&K replacements. The only sound difference is that the Mavin woofer will give you a bit more bass at lower levels due to the better efficiency. Available in 4 or 8 ohm versions. You can get yours at mavin dot com
