Thanks mtrycrafts.
The woofer is a JBL power bass 10.
By the way nothing is hooked up to the woofer. I just plugged it in.
It was in a entertainment center under the TV. I removed it from that location thinking there may be some feedback from someplace. Same results.
http://www.jbl.com/home/products/product_detail.aspx?prod=CREATUREII&cat=&ser=HMM
The JBL site has a manual but not trouble shooting solutions.
The unit has two dials non of which are volume controls.
I don't know what level matching id.
Thanks for helping me
