It's possible that the Martin Logans were too close to the wall.
In fact that's probably my number one issue with the blind testing - distance from wall is a constant. The truth is different speakers are designed for a different distance from wall and it shows in things rearward radiation in bipoles/dipoles and even lower midrange and upper bass in monopoles.
anyways I don't really know what to say regarding the ML measurements, but I will post this as it's relevant:
www.linkwitzlab.com/Editor-Stereophile-MG36.doc
Yes, that is an important consideration. In the test, all the speakers were in the same position. You can bet the position was right for the manufacturer's speakers, but that might mean that all of the others were in the wrong position.
That said, although I love flat panel speakers, I have never liked Martin Logan speakers. To be sure, I have not heard all of them, or any top of the line model, but the ones I have heard did not sound good to me for the asking price (both in the distant past, and within the past couple of years with new models). And I have wanted to like them; it would be nice to believe that a speaker made in the middle of the U.S. is great, and it would be nice for some exotic speaker to sound magical. But they have never seemed right to me, no matter which ones I have heard, or where I have heard them. Of course, maybe they were all set up wrong, or I only happened to listen to poor models, but they cost plenty for what they were.
I would be much happier with a test done by someone without a vested interest in the results. And it would be nice to see how the particular other models were selected. Are they representative of their respective brands, or are they unusually bad for them? Also, what music was selected, and why was it selected rather than other music? Was it selected because the house brand was particularly good at reproducing such sounds, or was it selected based upon some other considerations? Were there other tests done with different models that turned out badly for the house brand, so that they decided to pick different models until they got the results they wanted? Did they run the same test over and over with different results, but then only report the set of tests that gave the desired results? There are too many unanswered questions to come to any firm conclusions about the tests.
It might be that the Infinity speakers are the best, but we have no way of determining that from this article.
