Speaker options
The Yamaha is a good lead, I have a similar model.
On the speakers, you should consider the Pardigm Monitor Series or Klipsch Reference series for better performance in your large room. You should also consider bookshelf and floorstanding models from internet direct companies like Onix (av123.com), Axiom Audio, and Ascend depending on your budget.
