I have a weird "problem" (because I am cheap and trying to re-use components). Let lay our the problem, I have a TV in the basement that is only used while on the treadmill. We just use the speakers that are on the TV but they suck and sometimes struggle to get loud/clear enough over the sound of the treadmill when running on the treadmill. The TV is basic with only HDMI and TOSLINK outputs (I am not running a receiver down here, just streaming shows directly from the TV so that is the only audio source). I also don't really have enough space for a dedicated soundbar (the TV is wall mounted with other tables/desks below it) but I imagine I could find space for a bookshelf or center channel style speaker.
Given this is really only used for watching TV shows while working out, I want to be as economical as possible but I want better/louder sound from the TV.
- Should I be looking for an all-in-one solution, some sort of powered speaker that can take HDMI or TOSLINK?
- Maybe get a cheap amp with digital input and hook it up to some new speakers
- Get a cheap decoder for the HDMI or TOSLINK to analog, feed that into cheap amp, then into some speakers (or use the cheap decoder into some cheap powered speakers)
- I also have some old 3 way speakers in the same space but they are part of another system, what happens if I hook these up to a small amp from the TV but are also wired up to another amp? I would run both amps/signals to these same speakers at the same time...
I would love feedback on recommended approaches or something else I may be missing. Also open to specific suggestions too.
