Hello everyone,
I'm in the process of upgrading my home theater system from a 5.2.2 setup to a 9.2.6 configuration
I need some advice on amplifier upgrade/add-on options to my current setup. I currently have 7 channels of amplification covered (5ch + 2ch Parasound class AB amps). I need 9 channels of amplification for 2 front wides and 6 atmos speakers (8 channels if I decide to use only 1 center height channel for Auro 3D).
How do you feel mixing Class AB amps with Class D amps?
I am not interested in a super expensive amplifier since I will only need to drive the front wides and Atmos speakers, plus my Theater room is only L:17ft x W:13ft x H:8ft
I was considering the following options:
- $ Stark Fiera 8 (Fiera8 - 8 Channel Amplifier 8x130 Watts)
- $$ Monolith by Monoprice 9-Channel (3x200 Watts + 6x100 Watts)
- $$ Emotiva XPA-9 Gen3 9 Channel
- $$$ Marantz amp 10 (but that means I have to sell the Parasound amps which would be a pain as I don't have the original boxes anymore and I don't think I need 200W across all channels)
Any suggestions or insights would be greatly appreciated!
Current Setup:
Pre-amp/Processor:
- Marantz AV10 with 15.4-channel support
Amplifiers:
- Parasound Halo A51 (5 channels, 250W each @ 8 OHMS)
- Parasound Halo A21 (2 channels, 250W each @ 8 OHMS)
Speakers:
- Center and Front LR: PMC DB1i Bookshelf Speakers
- Sensitivity: 87dB (1 watt, 1 meter)
- Recommended Amp Power: Up to 150W
- Front Wides: PMC Wafer 1 On-Wall Speakers
- Frequency Response: 50Hz-25kHz
- Impedance: 8 Ohms
- Sensitivity: 87dB (1w, 1m)
- Side and Rear Surrounds: PMC Wafer 2 On-Wall Speakers
- Impedance: 8 Ohms
- Sensitivity: 90dB (1w, 1m)
- Rear Height in Ceiling: Monitor Audio C380-FX 8"
- Sensitivity: 90dB
- Power Handling (RMS): 120W
- Side and Front Heights: Still under decision. I have two pairs of Sonos/Sonance 6.5" in-ceiling speakers that I can use for the remaining Atmos speakers.
- Sensitivity (2.83V/1M): 85dB SPL
- Power Handling: 130 watts maximum
- Nominal Impedance: 8 Ohms
Theater Room Dimensions:
- Length: 17 feet
- Width: 13 feet
- Height: 8 feet
