Thank you very much gents for all the responses. I was able to locate a service manual so I'm good there. The problem is that the manual does not show how to take the woofer apart for testing and part replacement. Specifically, it does not explain how to separate the amplifier unit from the enclosure. I took out all the screws on the back and I'm looking through the huge speaker opening. I can't figure out if the emplifier is supposed to come off by pushing it from the inside out, or by pushing it from the outside and out the speaker opening. I must take the amplifier out as that's where the problem is. Has anyone removed an amplifier before from a HK subwoofer ?
