Locking HDMI Cables - Good or Bad????
I've had a multitude of issues with my YAMAHA RECIEVER RX-V475, which I bought at FRY'S, along with a 6.1 Surround sound speakers, I bought at my local Hsu Sound Speaker Company.
I have the 46' TV mounted on wall, with an In-wall CL2 certified 24G 12' HDMI Cable. Monoprice.
After constantly fighting with the signal loss, I went back to FRY'S, and since I had a one year warranty left, they exchanged the older unit, with a brand new Yamaha RX-V675....
After hooking this one up, same exact problem. So I know after having issues with both AV receivers, this problem is not the receivers themselves, but has to be with the HDMI cable male end.
I even replaced this cable with another from Monoprice, but still, the same issues.
I actually only need 10' ft. So maybe my problem is because it's braided, and that extra length is causing my HDMI cable to constantly lose it's signal, and I have to spend between 6 and 10 times per hour, ever slowly, moving the cable at the TV-IN Port, until I get a signal again...VERY FRUSTRATING! It's too stiff, in the back.
I contacted a place that sells locking HDMI cables, they told me that the only length they have to go in-wall, starts at 16' feet. Their 10' ft. is only a standard utility cable, and not rated for in-wall application.
Yamaha told me the shorter run the better, to help against degradation of the signal. (similar to speaker run lengths)
and to go get a standard 10' ft.HDMI Cable....SHOULD I BE CONCERNED WITH OVERHEATING, AND STARTING A FIRE IN THE WALL? I am not sure how hot these standard cables get, but again, I'm worried about the heat.
So, for an application with a mounted 46'' TV, with a distance run of needed 10', with the cable hidden inside the wall, and the only type of HDMI cable, that will help stop this problem, are LOCKING HDMI'S, which would you recommend? (Sorry, Monster Cable is not in my budget)
Thank You
